Impulse relay control
  • Hi,
    I have this ipulse relay circuit. I would like to control it with my Shelly 1
    I would like to put Shelly behind the wall button.
    What is the correct wiring?
    Hello and welcome to the forum, :)
    As far as I can see, you connect I and O in parallel to your buttons, as well as L and N as supply voltage.
    Good Luck. :thumbup:
  • Solution.
    Because I have 3 separately button, I had to change the original impulse relay to Shelly 1. O / 2 , I / A1 , SW / A2.
    Its working properly.
    My biggest problem when I tried to put Shelly behind the switch was I couldnt put Shelly 1 to Impulse mode. I set the relay button mode, but when it got an impulse closed the O/I circuit. When I put the "momentary switch" option, It work, but I got false result in the Home application. The lamp switched on , but the application seemed off.
