Shelly2.5 unresponsive, hot and noisy
  • Hi there,
    I've been using seven shelly2.5 modules as roller shutters for more than a month, but since a few days ago one of them stopped working.
    I took a look today and found about the module is very hot, a bit noisy (like blowing air), and not accessible anymore.
    I tried to hard reset it (10s and more press on the back button) but nothing happened, it doesn't go back to AP mode.
    Is it dead ?
    Please find attached some data I found through my home assistant install
    Have you tried hardreset, too?
    Disconnect O1 und O2! Importent in roller mode!
    • Disconnect Shelly from the mains (fuse off or pull out the plug)
    • Reconnect the mains (insert fuse or plug in mains plug)
    • Press / switch 5 times with the connected button / switch within one minute connected lamp flashes several times in quick succession (relay rattles a few times)
    • Shelly can be re-integrated -> e.g. SSID: shelly1-xxxxxx, IP: 192.168.33.1
    Good luck.
