Shelly 1L, SW disable via HTTP API
  • Hello
    I am integrating a Shelly 1L with Node-Red using the HTTP API. The Shelly is controlled via the SW input using a PIR, everything works fine. Is there a way I can disable the Shelly SW input, i.e. Can I disable the SW Input from Node-Red to stop the Shelly switching? I have studied the Shelly APi docs but can't see such a feature?
    Thanks
    C
  • http://<shelly-ip>/settings/relay/0?btn_type=detached sets the input to detached.. you can change it back to momentary, momentary_on_release or whatever you previously configured..
