Counter Flicker with load resistor?
  • As many others I’m experiencing some problems with a LED driver that has a soft start circuit. This results in a bright flash of the lamp every few seconds.
    I was wondering if it would help to put a 25w resistor in series with my load. I would expect the flickering to subside in off state and a worsened efficiency (by 25w) in on state.
    Any opinions on the feasibility of this approach?
    Thanks in advance!
  • The supply current of the Shely 1L flows through the LED driver in switched off mode. The input capacitor of the driver is charged. When the capacitor voltage reaches a certain threshold, it starts for a moment. The capacitor voltage drops and the LEDs are going off again.
    A series resistor won't help, the current will still flow.
    A parallel load can help, like the Shelly Bypass. But according to the reports here, not in all cases. What will help most likely is an incandescent lamp 230V~ parallel to the LED driver input.
  • Thanks for the explanation!
    So if I understand correctly the incandescent bulb would allow for the current to flow so it does not start charging the capacitor on the power supply?
    I’ll try adding a small incandescent light on the same power line and check if that works.
