Issues with the open/close
  • Hi, been scanning the forum to find something similar to thhe problem I have. But no luck.
    D/w v1 connects to the app, luxx is working vibration working tilt working. But I can not get the little b**tard to indicate open and close. Magnet on arrowside of the module.
    I'm down to the fact that the new unit is broken.
    Any suggestions on what to test?
    May the fourth be with you!!
    Brg
    Mattias
    Ok, you 're right. Shelly DW (first version).
    But the same applies to assembly.
    Has the electronics ever fallen down? Then have a look wether the reed contact has broken the glass.
  • Ok, tnx to your hint,
    I reluctantly dismantled the new unit! But you where right, the metal bracket that is triggered by the magnet was stuck together, slightly adjusted them and it works like a charm!
    Se attachment Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.
    Most appritited👍
