Hi, I am trying to find a way to bring the temperature readings from a Shelly 1 with Temperature Add-on into HomeKit. One approach I have been considering is using the Homebridge plugin homebridge http advanced accessory. That requires a URL where the current temperature value can be obtained, but I cannot figure out if that is supported. I see there are I/O URL Actions in the Shelly interface, but is there any way to obtain the temperature readings from somewhere?
URL call to obtain temperature reading from Shelly 1 with Temperature Add-on?
- AddOn
Super#River#30344 -
28. April 2021 um 07:08 -
Erledigt
- Offizieller Beitrag
perhaps this help you
https://shelly-api-docs.shelly.cloud/#shelly1-settings-power-0
settings/ext_temperature/{index} -
Hi, SebMai, this list of parameters does indeed seem promising! Thanks, I will investigate this.
I believe what the OP is asking is of paramount importance and I'd say more: I don't want to use something in the Homekit platform, I'm aiming to read the temperature just with a single http command. Is that possible ?
PS Unfortunately SebMai is pointing to (thanks anyhow for your usual help) doesn't help that much: as a first goal I aim to a single command rather than to analyse the answer to a generic status request
Dieses Thema enthält einen weiteren Beitrag, der nur für registrierte Benutzer sichtbar ist.
