SHELLY 3EM LOSES WIFI CONNECTION FREQUENTLY
  • The Shelly 3 EM since installation about 3 months ago frequently loses the Wi-Fi connection and reconnects after a few minutes. The Signal strength is "excellent" with -55dBm . I have several Shelly 1 's and Shelly 1PM where there is no disconnect to the WiFi . I have the latest firmware update :
    Current version: 20210413-154243/v1.10.2-gb89901a
    What is going wrong ?
    When active , all the figures are accurate . I use the Shelly Cloud App, the Web UI and the Shelly integration to Home Assistant .I have reset the 3EM several times , but the same problem persists.
    I look forward to your assistance.
  • I'd enable debug log in order to check why the device gets disconnected..
    http://<shelly-em-ip>
    then Settings - Device Info - Enable Debug Log
    After next disconnect check (or post) the logs..
    Did you solve the problem?
    I have the same problem as you
  • I have a similar problem. Connecting and setting up Shelly via Shellys WIFI goes without problems. Next connection of Shelly to the home WIFI also works.I can see Shelly on the network (I have tried DHCP and static IP). But subsequently I can no longer connect to Shelly. The browser detects the Shelly page, but no data is loaded and it ends with a connection error. The Shelly cloud app does the same. It sees the device, but no pairing occurs and ends up with a connection error. I've tried hard resetting and reconnecting several times and still the same problem.
