hey all!
I have a three-way circuit with two switches at two different polls. One connects to L and the other connects to O. I have two travelers between them. Would the following wiring work?
Thank you!
EDIT: so I tried the circuit and it doesn't work, but only because the software doesn't support it!
When the left-most light is toggled the SW2 in shelly is toggled on/off; I can see it in home-assistant. But the light does not toggle.
The solution for me was quite easy: I made a rule in home assistant that if SW2 toggles, then toggle the light.
But why should I have to make a work-around in HA? With a product that's already so well built and with customer service that's so amazing (I'm trying to build "brownie points" here), why not have this as a built in button type? ![]()
