Shelly H&T goes Homematic - with original firmware (V2)
    © 2019 Stefan K. (aka 66er) - detailed information about this at the end of the manual (#3)
    Hello everybody,
    even the Shelly H & T can be integrated with the original firmware in Homematic.
    A flash of third-party firmware like Tasmota is not necessary.
    This has the advantage that app and cloud compatibility are preserved.
    This description is version 2 of this little prject.
    # 1 Introduction and project presentation
    # 2 Settings Shelly
    # 3 Integration in Homematic
    Shelly H&T as a virtual device in Homematic
    In addition to temperature and humidity, the battery voltage and battery status can also be displayed as an option.
    Furthermore, a failure of the Shelly H & T can be detected and reported.
    All App and Cloud Shelly properties are fully retained, regardless of use in Homematic.
    Querying the information puts a strain on the battery and shortens its life cycle!
    In order to save the battery as best as possible, my implementation recognizes when the Shelly H & T sends its data. And then the information for Homematic is retrieved. An additional awakening of the Shelly H & T does not take place.
    The degree of extra battery load depends on the desired data accuracy and the resulting setting in the Shelly H & T.
    I myself run all installed Shelly on a Homematic Charly with CCU3 firmware.
    Shelly H&T:
    There is only 1 entry necessary in the Shelly H & T:
    To set the system variable in Homematic to "in order", we use the "Actions" function of the Shelly H & T, which can only be set in the WEB UI via browser.
    At this point, the note that currently the data can not be transferred directly via Actions to Homematic.
    Code:
    http://192.168.1.93:8181/x.exe?Antwort=dom.GetObject("Shelly-HT_Ausfall_1").State(1)
    Adapt the IP address and name of the used Homematic-system variable (here: Shelly-HT_Ausfall_1)
    That's all in this part of coupling.
    Now have fun with it. ;)
    If not yet available, please create a device (28) System Exec! Above that the commands are issued. (No entries are made in CUxD-Exec!)
    For 1 Shelly H&T we need 4 system-variables in Homematic:
    The name has to be the same, you named in the Shelly-UI in #2!
    Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen. Other names can be choosen by yourself
    Now, you 've to create:
    1 CUxD-device (90)
    funktion: Thermostat
    name: what ever you want
    Icon: should be freely selectable (I take the wall thermostat)The already created variables are assigned to channel 1 of the CUxD device.Futher, we need 1 channel of an existing or new created CUxD-Timer. The setup of the timer: Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.
    The code for SYSTEM|CMD_EXEC:
    extra/timer.tcl Shelly-HT_Ausfall_1 0
    Adapt the name of the system variable (here: Shelly-HT_Ausfall_1)
    At least, you create a program:
    (The 2nd IF line is not relevant for the process, but part of my CCU, will be omitted from you)
    The script in the programm:
    Please, as always, adjust the IP address, CUxD addresses and names of system variables
    Have fun and success with it. :thumbup:
    ____________________________________________________________
    The instructions including the scripts and pictures are subject to copyright. Anyone who infringes the copyright (for example, pictures or texts illegally copied and published on other websites), according to §§ 106 ff UrhG punishable, can also be warned for a fee and must pay damages (§ 97 UrhG).
    All rights reserved
