3EM stuck on stock firmware
  • Hi,
    I just bought my first Shelly devices. Among these a 3EM.
    I installed the shelly cloud app and got the 3EM connected to wifi and it is visible in the app under devices. I can control the relay of the device but in order to do anything else with it it tells me I need to update firmware.
    When I press the "CLICK TO UPDATE" button in the app it I get an interesting dialog saying "Your device needs to update so you can use it trought the app." and I can select "YES" or "NO". If I ignore the spelling errors and the "YES" or "NO" to something that looks like a statement and press "YES" it says "SUCCESS" and "UPDATING DEVICE". After that nothing more happens. I have tried this maybe 10 times.
    I discovered the generator for manual firmware update on this site which I tried as well.
    In my case this got generated to http://192.168.5.149/ota?url=http:/…HEM-3_build.zip
    The response I got was:
    {"status":"updating","has_update":false,"new_version":"","old_version":"20200130-155119/em3calibration_rebased@12279f18"}
    The firmware update section in the web UI says:
    "The current Firmware version of your Shelly device is 20200130-155119/em3calibration_rebased@12279f18
    No newer firmware available."
    I have also tried restarting the device.
    Any suggestions of what to do? Is it just broken or am I doing something wrong?
    Best regards,
    Gussoh
    Einmal editiert, zuletzt von Gussoh (22. April 2021 um 22:03)
  • Is the 3EM allowed to access the internet?
    Easiest possibility to check that: go to the WebUI and check if time is shown on the top right corner..
  • Thank you Seven of Nine!
    No, time is shown as --:--.
    Any advice on what to how to check the settings or troubleshoot?
    The network has nothing special. Standard DHCP settings.
    Best regards,
    Gussoh
  • No, time is shown as --:--.
    there's probably something in your network which blocks internet access.
    Some ideas:
    - active Firerwall
    - wrong Gateway configured (routing issue)
    - no DNS configured (name resoultion issue)
    A possible workaround would be to update the EM via local webserver (if there's a local server in your network)..
