flickering
  • Hi all,
    I have for some time now 5 shelly dimmers in use, they worked just fine till this day. Out of the blue they start blinking/flashing.
    I checked the the power/voltage supply this is just fine as it should be, I did an power off/on to the device, I replaced on one device the light source just to confirm it's not the lights itself.
    Also did an firmware update and an factory reset, nothing seems to be helping.
    Any of you have an idea what this might be?
  • I'm on 1.10.4 and I have some flickering on several Dimmer 2. The flickering occurs once every two-three minutes. I use different lights on them so I'm quite sure the Shelly's are the problem. All are wired with neutral and all lights are dimmable LEDs.
    It's very annoying.
