MQTT - Auto Timer
  • I have a question regarding Shelly-1 and how to set the timer in MQTT, so that the relay goes OFF after TT seconds. I'm using NodeRed as my control environment.
    I can get the relay to operate via http, using: http://IPaddress/relay/0/?turn=on&timer=2 , but alas not over MQTT.
    So far I've tried using the following topic in the MQTT node: shellies/shelly1-my_mac/relay/0/timer with TT seconds in the payload but it has no effect.
    Note that I can turn the relay ON and OFF via MQTT but I can't get the auto-off time to work,
    I would appreciate any insight into how to make this work.
    Einmal editiert, zuletzt von Wrapit (14. April 2021 um 13:53)
  • AFAIK MQTT supports only on /off / toggle as command.. all other attributes such as timer are supperted only for REST-API calls..
