Issue adding new device (shelly 1)
  • When I try to add the device the temporary network shellyswitch**** is not showing anymore
    I wasn't able to add it normally, and I was trying to follow the procedure to add it by ip, but the device "access point" is not showing anymore, Probably I need to reset the device but I can't see an obvious way to do it ...:(
    https://drive.google.com/file/d/1itw_3u…iew?usp=sharing
    This is not my first, I already have 6 other devices, and never had so much trouble adding one. I suspect that the fuckin' thing just died.
    Any thoughts?
    How to physically reset it?
    is standing one comment over yours...
    And from lexicon:
    Reset:
    Reset to factory settings:
    Disconnect Shelly from the power supply (fuse off or pull out the mains plug)
    Reconnect the mains (insert fuse or plug in mains plug)
    Within one minute, press / switch the connected button 5 times, connected lamp flashes several times in quick succession (relay rattles on a few times)
    Shelly can be re-integrated -> e.g. SSID: shelly1-xxxxxx, IP: 192.168.33.1
