Shelly EM with mqtt integration in HA stops one or two time at day
  • Dears,
    I have a Shelly EM meter, with mqtt integration to control the power of my house. One or two times at day the Shelly stops to send data to HA. If I access to the shelly ip address it seems to work correctly, by the data that I see with the ip address is not read by home assistant. If I reboot the shellly then all is working perfect, just to the next time, one day or two later....
    With this issue its impossible to control with utility meter the power conssumption at day or month, any time that this append I need to retart all the utility meter sensors.
    Can you help me?.
    Thanks,
