Shelly Dimmer 2 with two-way switches
  • I just installed a Shelly Dimmer 2 using the attached connection scheme, but the physical switches need to be kept untouched. Otherwise the dimmer can't operate.
    Did I connect it wrong?
    Is it possible to have the physical switches turn the lights on/off, while the dimmer only controls the dimming level?
    thanks and when I understand it right is your connection wrong.
    On your picture is the left one with the live wire and the right the one with the switched live to the lamp?
    So you have to change your wiring to this
    (It's untested)
    The dimmer needs to be fitted behind the right switch (green)
    Button type edge
    Switch on/ off
    Dimming WebUi/App
  • Thank you!
    I only know the switches have a wire connected to the L pole. I also think one of them is the live wire, and the other one goes to the 3 lamps, but can't tell you which is which.
    I can send photographs of the "before" setup, if you wish.
    In other words, I'd like the Shelly dimmer to act as a cross switch, linked to the other two, while also dimming from the app. Is that possible?
