Shelly 2 Dimmer wire connection with Dimmer Switch
  • Hi all,
    I am new to Shelly's world.
    I have installed at home this dimmer switch model (see attachment):
    Hamilton
    H-LEDSTAT-GR
    230-2440V - 50Hz
    5-100W max
    BS EN 60669-2-1
    Intelligent Dimmer
    and I would like to use Shelly 2 Dimmer to add the ability to control it over the phone. However, I would like to keep the current dimmer switch working as is.
    I have read here that it might not be possible to use any dimmer wall switch (standard or smart) with Shelly Dimmer 2. The only option is to replace the dimmer switch with regular switches or push buttons.
    In case that I cant achieve what I am after. Is there any other Shelly product that can achieve it? Or is there any plan to create a Shelly product to do it?
    In case that I can achieve it. Do you mind sharing a wiring connection? I have tried some combinations but none of them didn't work.
    Thank you in advance.
    Hi and welcome to the forum. :)
    You can only use your dimmer or dimmer2. Both is not possible,
  • Thank you @66er
    Do you know if there is a plan to make a Shelly version that supports regular/smart wall dimmer switch?
    Or if there is a different Shelly version that supports it.
