Hello,
wired Shely EM with 120A clamp. Unfortunately cannot get /energy values, but /power works fine.
Any suggestions on what could be wrong? Thank you.
Hello,
Hello,
Where do you see this parameter ? Because in doc, there aren't this value ?
https://shelly-api-docs.shelly.cloud/#shelly-em-emeter-index
| power | Instantaneous power, Watts |
| reactive | Instantaneous reactive power, Watts |
| voltage | RMS voltage, Volts |
| is_valid | Whether the associated meter is functioning properly |
| total | Total consumed energy, Wh |
| total_returned | Total returned energy, Wh |
Just looking at an EM3. The only settings I have changed are to enable MQTT.
Its a sunny day (yes it does happen in the UK) so it might be the solar panels
I will look tonight when there is no solar
Yes, but I can't help you for "why is empty" :
