SW1 control Output / SW2 detached for URL Actions
  • Hello,
    I own a Shelly Dimmer 2 that I use with only one switch plugged (SW1) and configured on the Shelly as edge switch
    I would like to plug another switch to the Dimmer 2 on the SW2 input, but I would like that second switch to be detached and have no efffect on the output. For example to assign I/O URL actions on it.
    Is that possible with the current firmware ? That could be a great addition.
  • Royal#Bar#30827 30. März 2021 um 18:46
    Hat den Titel des Themas von „Second switch mode“ zu „SW1 control Output / SW2 detached for URL Actions“ geändert.
  • Is that possible with the current firmware ?
    AFAIK yes..
    With Edge Switch (edge on/off mode with single switch. ) the first switch (sw1) is for internal control, The second switch (sw2) is in detached mode and can be used to control other Shellys via DDD-Actions ..
