Reading too low
  • I have an EM with two 120amp transformers one reading the main cable the other clamp reading a secondary fuse box. The main one works as expected the secondary one reads for example 4 wh when I turn on a heater which should read 5kw. The clamp is a little large for the cable could it be this simple?
    Thanks
