Wifi re-connect
  • Hi,
    Would there be a way to force a Shelly-Motion to re-connect to a WiFi network, after it disconnected?
    All I know how to do is to re-initialise it (by using the pin hole), but I was wondering if there was a 'reboot' pin hole sequence,
    without factory reset?
    Thank you for your help.
  • Hello,
    try to access through the web interface and select the reboot device item.
    however, the sensor has connection problems and if it does not detect movement for a long time it goes into sleep mode and never wakes up.
    no one is able to find a solution
  • I did some tests and downgrading to the previous version and assigning a static ip address seems to be fine. I wait until tomorrow to see if the problem recurs
  • Hi, in my experience it takes longer than 24 hours for the problem to occur.
    It seems to occur only after a week - maybe two.
    In that sense it is not too alarming, if it weren't for the fact that because I cannot connect to it on WiFi, I use the pin to re-activate the device. But that then essentially resets the device to factory settings.
    When and if it occurs again (I had it happening once on every device since I received them), I will try the 'connect test', where one claims after 5, 6 attempts to connect with the URL, the device actually starts responding again. I cannot tell if this works or not.
    I'll provide my findings when possible.
    Thanks!
