shelly i3 dead?
  • My Shelly i3 became unresponsive, not connecting to wifi. The red light is off, but the device is warm, so I am assuming it gets proper power. I have measured the live and neutral cables and there is no interruption on them (by measuring resitance between the cable's end and the pcb). If I reconnect the shelly, the red light lights up, but turns off after a few minutes. It's not connecting to a wifi network and does not create an AP. The reset button does not seem to to anything.
    Any idea what could be wrong?
  • Hello Molnart,
    Have you resolved the problem? I have exactly the same problem. First I had configuration problems, it would not store the config always the right way, after that the config was right but the switches still used the old config somehow. After a few minuts it became unresponsive and did not respond anymore. Tried a hard reset but no success. It looks like it is dead
  • hello, i did not. i had a lengthy discussion with shelly guys over facebook messenger suggesting different options, but none helped. they have promised to replace my device. you should take a look at the facebook support group, i think that is where the thing are happening, this forum is rather quiet.
  • "could be because few speak or write English here. In addition, we are all only buyers, this is not from the manufacturer itself."
    Classic business failure - We know what's best therefore we don't listen to the customer
