request URL for H&T
  • Hi there,
    I want to periodically collect the temperature and humidity readings from a H&T sensor and save them in a database. I'm already doing this for several other Shellies, (EM, 1PM and Plug) which are always turned ON and I can just ping them for the info and obtain a http return (http://192.168.1.xx/emeter/0 , etc).
    For the H&T this is more complicated since it only wakes up from time to time. I want to make use of the REPORT URL feature for this, which I believe would receive the status (temp and hum) upon wake up, correct?
    My question is how to do this...? I have a raspberriypi as a server running telegraf which periodically pings the shellies for the info as I mentioned above, so I configured it to get the data from the shellies IPs. For the H&T REPORT URL, I should configure the REPORT URL with the raspberry IP ? Should I point to a specific port ? Any tips on how I would edit the config file of telegraf to retrieve the data coming from the H&T ?
    Thanks!
  • Right, I know that the H&T is not reachable most of the time, that's why I want to have it push the information "somewhere"...
    My question revolves around how to do that. What address to put in the request URL, considering I have a server actively collecting the data from the other Shellies ?
    If I use the address of my server, how to then go from there...? Add a port in front of the address ? How can I get the information from the H&T saved ...? (bonus if someone can help me via Telegraf :)
  • Ich komme mit dem Shelly HT einfach nicht zurecht. Nirgendwo wird erklärt (für 3 Jährige), wie man eine statische IP für das Gerät anlegt oder wo ich die URL für die Einstellung der Temperatur und Luftfeuchtigkeitsgrenze finde. Vielleicht fehlt mir auch einfach die Ahnung. Kann jemand helfen?
  • Hallo und willkommen im Forum, Nadja77 . :)
    3 jährige beschäftigen sich schon mit Netzwerktechnik ? =O :/
    Spass beiseite:
    Dafür brauchst Du keine URL.
    H&T aufwecken (Taster betätigen) und die Einstellung entweder im Setup über die App machen oder das Web-UI aufrufen (IP-Adresse des Shelly im Webbrowser) und dort die Einstellungen machen. Dabei schnell sein, denn der Shelly geht nach ca. 3 Minuten schlafen und muß neu geweckt werden.
    Statische IP kann man in den Netzwerkeinstellungen des Shelly vergeben. Hier sollte man aber wissen, was man tut oder bei DHCP bleiben. Ein Fehler kann dazu führen, dass das Gerät nicht mehr zu erreichen ist. (Dann ist ein Werkreset der letzte Ausweg).
