Auto off nach 6 Stunden funktioniert nicht
  • Ich habe seit einigen Firmwares das Problem, dass das Auto off nach 6 Stunden nicht funktioniert.
    Auto Off steht auf der Startseite des Web-UI auf 0 Sekunden (bzw. direkt beim Öffnen auf -1 Sekunde).
    Kann das jemand bestätigen, dass lange Auto Off Timer nicht zuverlässig funktionieren?
    Auch im Status steht bei beiden, dass der Timer abgelaufen ist.
    Dimmer 1
    "rssi":-68},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":true},"time":"11:28","unixtime":1616408937,"serial":83,"has_update":false,"mac":"98F4ABD0357E","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"lights":[{"ison":true,"source":"input","has_timer":true,"timer_started":1616365622,"timer_duration":21600,"timer_remaining":-1,"mode":"white","brightness":10}],"meters":[{"power":0.47,"overpower":0.00,"is_valid":true, "timestamp":1616412537,"counters":[0.463, 0.467, 0.467],"total":680}],"inputs":[{"input":0,"event":"","event_cnt":22},{"input":0,"event":"","event_cnt":0}],"tmp":{"tC":44.27,"tF":111.69, "is_valid":true},"calib_progress":0,"overtemperature":false,"loaderror":0,"overpower":false,"update":{"status":"idle","has_update":false,"new_version":"20210319-122304/v.1.10-Dimmer1-gfd4cc10","old_version":"20210319-122304/v.1.10-Dimmer1-gfd4cc10"},"ram_total":48856,"ram_free":35980,"fs_size":233681,"fs_free":128010,"uptime":200929}
    Dimmer 2
    "rssi":-61},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":true},"time":"11:33","unixtime":1616409236,"serial":27,"has_update":false,"mac":"40F52001A156","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"lights":[{"ison":true,"source":"input","has_timer":true,"timer_started":1616365618,"timer_duration":21600,"timer_remaining":-1,"mode":"white","brightness":11}],"meters":[{"power":3.72,"overpower":0.00,"is_valid":true, "timestamp":1616412836,"counters":[3.806, 3.811, 3.798],"total":3348}],"inputs":[{"input":0,"event":"","event_cnt":7},{"input":0,"event":"","event_cnt":0}],"tmp":{"tC":44.89,"tF":112.80, "is_valid":true},"calibrated":true,"calib_progress":0,"calib_status":0,"calib_running":0,"wire_mode":1,"forced_neutral":false,"overtemperature":false,"loaderror":0,"overpower":false,"debug":0,"update":{"status":"idle","has_update":false,"new_version":"20210318-141630/v1.10.0-geba262d","old_version":"20210318-141630/v1.10.0-geba262d"},"ram_total":48224,"ram_free":35364,"fs_size":233681,"fs_free":116966,"uptime":201249}
  • Gezählt wird ja anscheinend korrekt, nur geschaltet nicht, wenn die Zeit abgelaufen ist. Vielleicht kommt der Shelly mit dem Status "-1" nicht zurecht, wenn die Zeit abgelaufen ist?
