Motion Sensor
  • Hello,
    Just received the motion sensor and it works great and is quick to respond and working with Alexa Routines.
    I tried to disable the sensor at sunrise with the "Weekly Schedule" via webui and it doesn't seem to make a difference. When it should be disabled, it still fires motion action (red led and motion sensed). Using the latest firmware 1.1.1 and time is synced and correct.
    Thanks!
    Regards,
    -Ron
  • I also had same problem, planned schedule at sunrise/sunset not working, I was able to solve the problem like this:
    1. Under setting/Timezone and geolocation uncheck the "automatically detect Time Zone"
    2. Leave all the data (local time, geo-location coordinates) unchanged
    3. Click "save"
    That's it. With manual geolocation settings, the schedule started working at sunset/sunrise correctly.
    I tried couple of times to revert back and forth from manual to automatic and it behaves consistently: auto-> not working, manual-> working
    Hope it helps
    Emanuele
