Detects motion, Lights stay off
  • Just using Phone app, Added to room, detects motion but wont activate any of the shelly 1s or 2.5s in the house, I have a 2nd one installed in bathroom, works great. I have added it many times, rebooted router,
    updated firmware, it's : is 20210304-134216/v1.1.1@6e2583cf.
    Had a little trouble adding it to app, kept saying "wrong secret code try again"
    Then the "Discovered devices" would never drop down in the app even after it said it was successful adding it to WIFI. Web page shows it seeing motion all looks good, just won't trigger anything.
    any suggestions would be welcome! Thinking about sending it back. Other motion sensor installed just fine works great.
    thanks!!
  • I used the "quick setup" inside I/O URL actions. Just like I did when setting up the one in the bathroom and it works great, I have tried having it trigger some of the other shellys in the house, but no joy.
    It sees the motion, but never triggers anything, Have tried reinstalling it many times. Thanks for the help!
    I compared it to the one in the bathroom in shelly cloud and under : "motion detected" the Enabled is checked and it has [object Object]
    in the line below, Same for no motion detected.
    The new one does not have any of that, When I try to add it I get
    "could not send command to device"
    Einmal editiert, zuletzt von tomw8073 (20. März 2021 um 11:12)
  • THANKYOU!! That worked. Had to google how but not hard.
    Tried to change some settings, said "couldn't command device"
    Thanks for your help, but not going to waste any more time, upgrading, downgrading, uninstalling, installing, talking to support on a 40 dollar motion sensor that seems to be unreliable at best.
    Einmal editiert, zuletzt von tomw8073 (21. März 2021 um 02:24)
  • Dieses Thema enthält 25 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
