BUG Shelly middle point 50% calibration
  • Hello all,
    Can it be possible to add a paramter in the options of a Shelly 2.5 in Shutter mode?
    Some shutters need some time from totally closed until they begin moving the bottom-most part and opening.
    The way its done at the moment the scroll bar and the tral blind are not real since fom 50% i must introduce 66%
    The parameter should read like "Half way shutter position". If you enter a position in %, e.g. 66%, the shutter position 66% will be interpreted as 50%, so it will be read as 50% and if you set 50% it will go to 66%. So 50-100% values will be crushed to 66-100% values and 0 - 50% values will be expanded to 0 - 66%. This way the shutter will be half way down on reading or setting 50%. Right now I have to set 66%, because it takes the moter longer to go to the end position.
    The Tasmota theam has introduced this feature in the firmware, look here: https://tasmota.github.io/docs/Blinds-and-Shutters/
  • Hi and welcome to the forum. :)
    Feature Request please to Allterco. ;)
    Hello,
    Thanks for the welcome.
    Regarding the Allterco what is it?
    And this is not a feature request, is a bug fix.
    On the shelly app the roller bar middle point dont correspond to the physical middle point of the roller, so we must see this as a bug fix and not a feature.
    On our cars the speed indicator say you are going at 100km/h, and you cant be in real going at 120km/h or can you? Otherwise you are being lead to mistake.
  • Hi,
    this isn't realy a bug. Other products like Homematic as example have the same "problem".
    Allterco is the producer of Shelly. Only Allterco will fix it perhaps, if many user ask for it.
    You find a button to Allterco Ticketsystem on the left side here. ;)
    Hello,
    From the moment you say its a "problem" you are confirming that is a bug from Shelly and like you say from Homematic.
    Doesnt make any sense that the middle point doesnt match the 50%., and it cant be calibrated.
