• Erster :P
    Firmware 1.10 Final ist raus:
    Viel Spaß beim Updaten.
    Hier noch das Changelog:
    * [All devices] Add new property fanSpeed to CoIoT
    * [All devices] Add new unit pct to CoIoT
    * [All devices] Add new endpoint /cit/d to retrieve CoIoT description package over HTTP
    * [All devices] Add attributes ap_roaming.enabled, ap_roaming.threshold and parameters ap_roaming_enabled, ap_roaming_threshold to /settings endpoint
    * [All devices] Add attributes coiot.enabled, coiot.peer and parameters coiot_enable, coiot_peer to /settings endpoint
    * [All devices] Add attribute/parameter debug_enable to /settings endpoint
    * [All devices] Add attribute/parameter allow_cross_origin to /settings endpoint
    * [All devices] Fix unixtime to be UTC
    * [All devices] Add new endpoint /ota/check
    * [All devices] Add new endpoints /debug/log and /debug/log1
    * [All devices] Add mode to MQTT shellies/<shellymodel>-<deviceid>/announce response (when applicable)
    * [All devices] Update description of /settings/actions endpoint
    * [All devices] Make it possible to retain MQTT LWT topic (add attribute mqtt.retain and parameter mqtt_retain to /settings endpoint)
    * [All devices] Add info on max supported schedule rules
    * [Shelly Door/Window 1/2, Shelly H&T, Shelly Smoke, Shelly Flood, Shelly Button1] Add new endpoint /sta_cache_reset
    * [Shelly 1/1PM, Shelly 2, Shelly 2.5, Shelly Plug/PlugS, Shelly EM, Shelly 3EM] Add attribute/parameter wifirecovery_reboot_enabled to /settings endpoint
    * [Shelly 1/1PM/1L, Shelly 2, Shelly 2.5, Shelly I3, Shelly Uni, Shelly Dimmer 1/2, Shelly RGBW2] Clear input events after a pre-defined lifetime; don't publish input events on periodic MQTT updates
    * [Shelly 1PM, Shelly 2.5, Shelly I3] Add MQTT topic shellies/<model>-<deviceid>/temperature_status
    * [Shelly 1L] Update possible values of attribute/parameter default_state in /settings endpoint
    * [Shelly 2.5] Drop meters array from /settings endpoint
    * [Shelly Dimmer 2] Add attributes/parameters pulse_mode_detected, pulse_mode_rebooted, load_autodetect to /settings endpoint
    * [Shelly Dimmer 2] Add attributes calibrated, calib_status, calib_running, wire_mode and forced_neutral to /status endpoint
    * [Shelly Dimmer 1/2] Add attribute/parameter zcross_debounce to /settings endpoint
    * [Shelly Dimmer 1/2] Change type of attribute loaderror (from bool to number) in /status endpoint
    * [Shelly Door/Window 1/2] Add report_url (URL to report sensor events on) to /settings/actions endpoint
    * [Shelly Door/Window 1/2] Add attributes/parameters vibration_sensitivity and lux_wakeup_enable to /settings endpoint
    * [Shelly Door/Window 1/2] Update possible values of attribute act_reasons in /status endpoint
    * [Shelly Door/Window 2] Add tmp object (temperature sensor reading) to /status endpoint
    * [Shelly Door/Window 2] Add temperature_threshold, temperature_units and temperature_offset parameters to /settings endpoint
    * [Shelly Door/Window 2] Add MQTT topic shellies/shellydw2-<deviceid>/sensor/temperature
    * [Shelly Flood, Shelly H&T] Add id to report_url
    * [Shelly Flood] Fix sleep_mode.period description (it's not a configurable parameter)
    * [Shelly Gas] Add valves array to /status endpoint; add new endpoint /settings/valve/0
    * [Shelly Gas] Add MQTT topics shellies/shellygas-<deviceid>/valve/0/state and shellies/shellygas-<deviceid>/valve/0/command
    * [Shelly Bulb] Fix description of effects
    * [Shelly Uni] Add missing input events to /status endpoint
    * [Shelly Button1] Store input attribute event_cnt to RTC memory when device goes to sleep
  • Dann kann ich ja jetzt auch "offiziell" um eine Erläuterung bitten (vielleicht auch mit einem Beispiel?)
    1. Was ist "Enable CoIoT"
    2. Was ist "Allow Cross-Origin Resource Sharing"
    mit "dem Rest" komme ich klar.... zu den zweien oben finde ich nichts was ich "verstehe" :-)
    vielen Dank :-)
    zu 2: wenn es das ist, was ich vermute (wissen kommt nach Installation und Tests), dann kann ich es nun mit HTML, CSS, Canvans und Javascript schaffen, eine (einfache) Visualisierung in eigenen Netz im Browser zu erschaffen. Und dies ohne ein "übergeordnetes System".
    Warum nicht vorher: angenommen, mein Browser läuft auf IP 192.168.2.113, mein Shelly auf 192.168.2.74. Dann hat der Browser wegen der CORS-Richtlinien (IP 113 <> 74) hier mit einem gewissen "Unverständnis" reagiert, da der Shelly nicht mitteilen konnte, das dies "erlaubt" ist.
    Gruß Detlev
    FB 7590, MESH-Repeater, 1*Plug, 4*PlugS, 2*2.5, Dimmer2, 20*Shelly 1, 5*Shelly Plus 1, WiFi-Marker, BT-Scanner, Switchbot, App HTTP-Request, App Automate
    Einmal editiert, zuletzt von Deti_Hkln (18. März 2021 um 22:16)
  • Schön, liest sich gut mit viel Text ;)
    Ein nicht "Netztwerkfreak", kann da nichts mit anfangen.
    Fanspeed am Shelly, hat der nen Lüfter?
    Ein paar Fehler behoben kann man verstehen.
    Auf dem ersten Blick habe ich nichts gelesen (verstanden).. zu, behebt das jetzt automatisch die Probleme, Shelly nutzt automatisch den besten AP und nicht mehr was er zuletzt kannte?
  • Dieses Thema enthält 45 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
