Combine weekly schedule with timer
  • Hello,
    Im a beginner and must ask this, is it possibile to combine weekly schedule with timer, ex 1 minute power off timer then use switch input and combine that with weakly schedule sunset on and sunrise off, then i test this setup on an Shelly 1, it power on but power off regardin setting on timer, i want timer function when i use switch input and schedule timer whitout timer inteference.
    Regard Stig
    I hope I understand it right.
    You wish is that the shelly turns on and off with sunset and sunrise.
    But when you switch it on with your switch it should only stay on for 60 seconds.
    It isn't complete what you want but I think it's near.
    -Set sunset and sunrise timer
    - in this time don't use the switch
    -> last command is the winner
    - set button to detached
    - make a localhost action with an timer
    -> ex. http://localhost/relay/0?turn=on&timer=60
  • I'm looking for a similar thing.
    I'd like to see a checkbox on the schedule entries that states "triggers timer", so we can have on and off events in the schedule that don't trigger an auto on or auto off event.
    As an example, my immersion heater I want to run on the schedule, but when I ask Alexa to turn on the immersion heater I'd like the auto off timer to fire after 90 minutes.
    Hope that's a good use case for the separation of the timer from an individual on/off schedule event?
    regards
    Steve
