Another wiring question....
  • Hi there,
    This is probably a classical question but couldn't find the answer :x
    I have a 2 way switch but it is connected the way on attachment. I also add a photo of wiring on the "main switch" were I also have a neutral cable. The second switch is located upstairs and it only has the 4 wires that show up in the 1st picture - earth, comm, L1 and L2.
    Any ideas how to add a shelly 1L with neutral here?
    Many thanks!
  • hmm...
    Trying to understand it better :/
    Yes - the neutral is from the same breaker. Basically each main switch has a neutral loop - I believe this to be the norm now on new builds. That is the easy part on the wiring - just connect it to the N in the shelly using the connector to add one more wire to the shelly
    What I am struggling to understand is how will I get the other connections - I gather that L1 and L2 would go to Sx1 and Sx2, the current Comms would stay there but will need a junction to get to Sx, but were would I get the 0 wire?
    Or am I completely wrong on my assessment of the electrical installation?
    Thanks
    I can't measure your wires but you need to find live and the wire for the lamp.
    The live wire goes at L
    The wire for the lamp at O
    So please check your wires a bit more.
    And no, you have to change positions or disconnect some wires only as example at you first picture.
    Let's say the blue is live and brown for the lamp
    So is the connection for this picture
    Blue (disconnected from common) = connected to L from shelly
    N = N (isn't in this picture)
    Disconnected from connector Brown = at O from shelly
    Now comes the changes.
    First switch at common wire to SX
    Disconnect L1 and L2 from switch
    Grey will connected at common too
    Put a wire from L1 at SW1
    Put black wire at SW2
    Second switch
    Disconnect brown from common
    Put grey from L2 to common
    Black at L1 dissent changed.
    Now is there a wire between box one and two which isn't used (brown) , please make sure that it is safety in your box with an wago or an connector.
  • OK - I think I got it
    Switch 1
    - the Common wire is live which will go to to L in the shelly
    - The brown connector which has 2 wires - one will be for 0 (dark brown in the photo) the other one (which is the light brown which is also on switch 2 will no longer be used (need capped)).
    - New wire from Comm to Sx.
    - Switch L2 (gray) to the Common as well (it could be made with black one and change how we organised changes in switch 2)
    - New wire L1 to Sw1.
    - black (was on L1) wire to Sw2
    I was wondering if I could use the light brown (the one that will be capped) instead of the grey and cap the grey in both switches
    Basically on switch 2, grey capped, leave the Common on common and L1 on L1 (black)
    and on first switch - connect the light brown from the connector to the common plus a new wire to Sx.
    eg basically I believe this would just be using the light brown in my box as common wire instead of the grey.
    (attached switch 2 wiring)
