Bulk_control command for 2.5s
  • hey guys,
    I'm playing around with shortcut app in iPhone and would like to close/open several 2.5s with Siri commands.
    I found the bulk_control command, but it only has turn on/off commands. Or does it work also with direction open/close, like controlling only one shelly? Thanks.
    it should work the same way, only the url need to be changed a bit.
    I think it was ..relay/roller/..
    But I'm not sure, I can search it later again
    Zitat
    The syntax of the command for open and close is:
    POST link: https://[server location link]/device/relay/roller/control/
    Keys: direction=[command]id=[deviceID] - you can check the channel from Settings->Device informationkey auth_key=[auth_key]
    Where:
    directions: open, close, stop
    deviceID: device id which you want to control. You can copy it from Settings -> Device info auth_key: The key which you copy paste from your account.
    and instead of control you use bulk_control
  • it should work the same way, only the url need to be changed a bit.
    for bulk_control roller doesn't work, tried it already. I have already the roller with open and closed and position too, but I want to use the bulk_control to close more than one. Or does it work also with more actions in Shortcuts app in iPhone?
    I guess it must be relay, but in API says it works also for roller shutter mode. Not sure how it should work, can someone help?
    okay have done it , it's working with the shortcuts app.
    The one device way you are knowing, so I think you will get it.
    Please let me know if it is working with more devices, I have only one in roller mode.
    Try more devices like this.
    [{"id":"8015a3"},{"id":"8015a3"}]
    Here two screenshot from the app.
