Actions with timer option
  • Hi
    I want to turn on the garage lights when I open the door and turn them off after automatically after 40 seconds.
    I have a Shelly1 on my garage door and I want to control the garage lights that are connected to a Shelly2.5
    When I set the action on the Shelly1 I cannot save the option timer.
    Shelly1 - On the Actions I enable the "BUTTON SWITCHED ON URL" and add http://[shelly2.5 IP]/relay/0?turn=on&timer=40
    I save and when I go back to the Actions menu, I only have http://[shelly2.5 IP]/relay/0?turn=on, the &timer=40 option was removed :(.
    Everything works fine without the timer option, but I would like to have it (firmware 1.9.4)
    Regards
    João - PT
    • Hilfreichste Antwort
    Hi and welcome to thge forum. :)
    If you don't have done so, try to setup the action via WEB-UI. ;)
  • Thank you for the advice it worked just fine. 👍
    Now the lights turn on when I open the door, but also when I close the door.
    How can I solve this situation, because I only want the light to turn on when I open the door?
    The action is only on the "BUTTON SWITCHED ON URL".
    I have a magnetic switch to know when the door is open. With this switch I also know when it is opening and close, because the status changes (opens Off to On) (closes On to Off).
    How can I use this information to control the lights?
    João - PT
