Dimmer 2 with relay and 3 push button
  • Hello,
    I'm looking for help. I can't find exactly what I'm looking for and actually don't know if my idea could work.
    I have 3 push buttons,1 relay and 1 dimmable lamp. I'd like to wire dimmer 2 and keep my relay. Eventually replace my relay if I have to. I must keep my 3 push buttons !
    Could it work ?
    Thanks for your help.
    Regards,
    Mathieu
  • Yes it works. My whole house is set up like this. I have no conventional switches left in the whole house, and all switches can hence also be activated by the app.
    Also, the wiring in the switches has been replaced by very thin wire, because almost no current is needed to go through the switches.
    The TL also has a 4 wire version, I use that one, because then the I3 can read the status of the TL (open/closed).
    It just requires a large cabinet and a lot of electrical wires. But then, that is the cheap part :) :)
  • Thanks for your response. What would be the wiring for this specific scheme ? Replace my existing relay or keep it ? Do you think dimmer would work ?
