Shelly Motion and Home Assistant
  • I just got the new shelly motion a couple of days ago, I am having an issue connecting it to my home assistant.
    I have multiple other shelly devices including a PM1 several bulbs and the door and window, they all work as expected.
    When I attempt to add the motion sensor the error message is "failed to connect." I am using the correct IP (I am connected in a different tab) and my firmware version 20210226-072307/v1.1.0@f31e1d2b. The device is on the same network as the other devices, later today I may try and move it to a different wireless network and see if that makes a difference.
    Also I can connect via web browser and the shelly app.
    Any ideas am I missing something?
  • I was out when I returned HA detected the motion sensor and when I attempt to configure this is the error. It is the same error if I attempt to add manually.
    The IP Address is correct.
  • I haven't been able to have home assistant find mine yet. My wifi motion sensor is on a different network than my home assistant but I added the home assistant IP to the CoIoT setting for the device. I haven't tried just setting it up to use MQTT directly since I'd prefer to use the integration if possible. Does anyone have the specific things that need to be setup for the home assistant integration to work with this sensor?
  • I just tried today with my first Motion sensor and everything worked as expected.
    I'm running 20210226-072307/v1.1.0 and Home assistant core 2021.2.3
    When installing it I did press the button to wake the device up before inclusion.
    Also I beleive Home Assistant doesn't support "Restricted Login" so make sure that's disabled.
    After that the only thing I needed to configure in the Shelly Motion, after it was included in Home assistant, was to Enable CoIoT and entre the IP address of my Home Assistant with port 5683.
  • The way I was able to get it to show up was enabling MQTT pictured below. I am just beginning with home automation and I have not set up MQTT yet. It is on the list of things to learn.
    Once I checked the box HA detected the device and I was able to import.
    What throws me is I did not have to enable MQTT on any of my other devices. One of the things I like about Shelly is working right out of the box. Hopefully this will help someone.
