None of my Shelly Dimmer 2 report usage when lights are dimmed and power falls below (+/-) 2,5w. Above is fine, below is not. Lights are burning then, dimmed, but still at considerable strength like >30%
I'm using led lights everywhere
Dimmer 1 has no problem with lights at low strength and reporting even below 0,1w depending on the amount of lights and dimsetting. When I use a Dimmer 1 on the same light as dimmer 2 it has no problem reporting below 2,5w
I have asked this on other forums, facebook Shelly support group, several times and never even had a response once....
Trying my luck here ![]()
