Shelly 1PM with rocker switch
  • Hi,
    I have a 1PM with firmware 1.9.4 connected to a rocker wall switch and it's working correctly.
    The problem I have is that when I switch ON the light in the app (with the wall switch in the off position), to turn it OFF on the wall switch I need to change it to ON position and again to OFF. Same happens in I turn it ON on the wall switch, then OFF in the app, to turn it ON again I need to change the wall switch to OFF and again to ON.
    Is this the expected behavior?
    In the button type configuration I'm using "Toggle Switch".
    Is it possible to configure it in a way that whenever I toggle the wall switch the light status toogles also, even if I turn it ON or OFF in the app?
    Thanks
  • It worked. For some reason I has getting an error but when I changed to "power on default mode" to "restore last mode" I could set the Edge Switch mode.
    Thanks
