Shelly 1 as a dumb switch state detector (for use with home assistant?)
  • Am I able to use Shelly 1 purely to detect the on/off state of a dumb switch? I would like to detect the on/off state of the dumb switch and trigger automations through homeassistant accordingly.
    For example, I would like to change a Yeelight bulb colour to green when the dumb switch is on, and to red when the dumb switch is off, via homeassistant. This yeelight is a completely separate table lamp which has no connection to this Shelly 1.
    I do not want Shelly directly wired to any appliance.
    Would the below work?
    Externer Inhalt i.imgur.com
    My plan is to connect only:
    Live wire to L
    Neutral wire to N
    Dumb one-way switch to SW
    I and O left unconnected
    Thanks in advance!
  • I have tried to do "this" without success and it's frustrating the hell out of me!
    I have a 120v water circulating pump that is activated by a thermostat and relay. I tested connecting L to SW on the Shelly before installing and all worked as expected.
    When the thermostat relay activates it provides 120V to the pump, so I simply took a pigtail from the relay to the SW on the shelly. The thermostat relay activates, the pump runs, the SW lead goes high, but the Shelly does not recognize it and I can't figure it out.
    Clearly the pump has a voltage drop across it, but it looks like the correct voltage on the SW on the Shelly.
    What AM I missing/being stupid about?
    (Btw - I tried with and without detached button type with the same results. I have 6 other Shellies which are working perfectly, and I'm sure it's not a Shelly issue per se, it's me!!!)
