Shelly 1 and Wifi of a Netgear PWL1000 (V1/V2)
  • Hi All,
    I recently purchased 5 Shelly 1 to make some home automation.
    I have a 2 floors house: Internet modem on 2nd floor (with 2 Wifi, one 2.4 Ghz and the other 5 Ghz, 2 different SSIDs), 1 Floor with a powerline receiver from NetGear PWL1000 (tried V1 and V2 I have both) with 2 wifi (different SSID from 2nd floor).
    I installed the first Shelly 1 on 1st floor connected to the 2.4 Wifi of the powerline and no problem.
    If I try to connect a SECOND Shelly 1 on the same Wifi of the poweline receiver, the powerline starts to reset itself.
    No problem if I connect the 2 Shelly 1 on the Wifi of the 2nd floor, but signal is poor.
    Seems there is some "incompatibility" between Shelly 1 devices and Netgear PWL 1000.
    Last firmware (official, not beta) installed on all devices (Shelly and Netgear).
    Some suggestions?
    Thanks,
    Dimitri
  • Hi Dimitri
    I have the same problem. Did you find a solution?
    Best regards
    Essi
    über 40 Shelly's an 3 verschiedenen Standorten im Einsatz.
    Shelly's eingebunden in Home Assistant und apple Homekit
