Shelly Dimmer 2 API: what's the difference between "loaderror" and "overload"?
  • The API documentation for the Dimmer 2 states:
    loaderrorboolWhether a load error has occurred
    overloadboolWhether an overload condition has occurred
    In my case, I'm getting sporadic ERROR 1 problems on two of my Dimmer2 shellies.
    When this error occurs (1 every 10 tries), it's usually a few seconds after turning the wall switch ON.
    At this moment the lamp goes OFF and the web GUI shows "ERROR 1".
    Using the HTTP REST API I (<ip_address>/status) immediately after the error I also see:
    "overtemperature":false,"loaderror":1,"overpower":false
    Pressing the wall switch once more resets the error and the light goes ON.
    What does "loaderror", "overload" and "overpower" exactly mean ?
    What can I do to fix this problem?
    Thanks!
    Einmal editiert, zuletzt von joseLRD (26. Februar 2021 um 11:23)
