Shelly 2.5 in roller blinds - 5 cables
  • Hello.
    I need to connect my shelly 2.5 to a roller blinds. I don't have a switch, they work by RF.
    5 cables come out of the roller blind motor:
    - Brown - Line
    - Blue - N
    - Green/yellow - Ground wire
    . Black
    - White
    When the black cable touches the white, the roller blind goes up, then it touches again and it stops, it touches again and it goes down and so on...
    Is it possible install Shelly 2.5 in my roller blinds motor?
    What is the scheme and which settings in app?
    Thanks a lot for the help
    sorry for this answere now...
    No it isn't possible.
    The problem is your motor.
    Black and white are only for an dry contact (push button or smart ->shelly1)
    And with this it isn't possible to know if open or close, and percentage too.
    But for knowing if it is open or closed, you can use an addon with an reed contact or switch. So you know one position.
