Two Way Switching With Shelly 1 - Irish/UK wiring
  • I purchased a Shelly 1 for some spotlights which are controlled by a 2 way switch. I got an electrician to install the Shelly but he told me it wouldn't be possible to wire it without blocking off 1 of the switches as the switched live and live are at different switches. Is there a way it can be wired without blocking off 1 of the switches.
    This is the switch with the netural and switched live
    This is the switch with the live
    This is the wiring in the rose of the spot lights
    Is it possible to wire a Shelly 1 to get both the switches working or would a Shelly 1L be better in this instance? What would the wiring diagram look like when connecting it up?
    Thanks
    There are 3 possibilities:
    1. Change your switches against push buttons/ momentary switches.
    2. (If it is allowed in your country)
    Change the wiring that you have live in the second switch and neutral in the first, than use 2 shelly1
    3. Use a Shelly 1L , perhaps is the bypass needed.
    For wiring diagrams take a look into the lexicon, there are some examples.
  • Hello AyeKay2021
    as described in the other thread with shelly1L an this diagram.
    12708-ar768-wechselschaltung-ohne-n-png
    if the power is below 20W then bypass parallel to the lamp.
