Shelly Flood Battery Life
  • I recently got a Shelly Flood Sensor and updated it to the latest firmware currently available.
    My problem is that the battery is completely eaten up in 1 day! Completely pathetic!!! I’ve tried a variety of settings etc with 3 batteries now.... so 3 batteries in 3 days. What a POS.
    All the settings on the Flood Sensor are default except for the following:
    - Static IP address configured
    - Username / password on the interface
    - Cloud disabled
    - MQTT enabled
    At first I thought maybe the signal quality was not good (as it was behind the wash machine), so I moved it now to my desk (about 1m away from the AP [UniFi UAP-AC-Pro]) and even there the battery is dead within a day.
    Anyone else having this problem?
  • Hi,
    My new Shelly Flood did work more than one day but after 3weeks the battery was empty also. Updated to the last firmware and an static IP-adres...thats all. It is 4 meters away from the wifi-router without anything in between.
    Is there something wrong with the device? Should I send it in for replacement?
    Grts
    Mario
  • I have the same problem. When I start the device is gives sounds like an old hard disk (like those which are not SSD) ... is it normal sound? Then, after about 1 minute LED gets off. Within few hours the battery is dead. The same battery in Shelly door/window lasts more than months. I tried variety of settings and nothing helped.
    What can cause such power draining?
