webui not working correct
  • Hi all,
    On my shelly-1 (v3) the webui stopped working (see attached picture). Even after a reset I am unable to change settings.
    The unit was only about 4 weeks in use.
    Is there a solution for this issue?
    Thanks in advance
    --Gerard
  • Thanks for the overwhelming replies (not) but I solved the problem kind of.
    Since a factory reset didn't help I did a reflash with the recovery image. From there upgraded to the latest and I worked again.
    The only disadvantage of using the recovery image is that the deviceID is changed to half the length of what is was. By hard setting the mqtt topic the original topic could be reused.
