I was running version 1.8.3 and saw an firmware update was available in the Shelly Dimmer 2 UI. After pressing upgrade firmware and waiting for a while, the Shelly started displaying files like an FTP site. I tried the Firmware Archive to upgrade and downgrade, but website just gives a Not Found response. Any idea how to fix this?
Serving Files instead of WebUI after upgrade
- Shelly Dimmer
Arnoldsly99 -
15. Februar 2021 um 21:25 -
Erledigt
I have same problem
How can you fix it?
How can you fix it?
i have same problem
I just got my first Shelly dimmer. I was trying to connect it to network without succes. Then i discoverd the same problem that guys above me have.
So Shelly support, what to do?
I had this also. You just have to allow the device to init itself, and after a while, the normal web UI appears. Allow the device to start up, and all will be okay
Dieses Thema enthält 9 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
