Cannot connect WIFI for installation of Shelly 2.5
  • Hello everybody,
    I recently purchased several 2.5 Shelly for my rollershutters. 3 of them are working fine so far. But for 2 of them, I cannot complete installation. After wiring (like the other ones), I see WiFi AP of the device, start installation of it, but ones my phone (android) get connected to the local AP shelly wifi, I get an error:
    "Could not send WiFi settings to device shellyswitch25-XXX. The response from the device was: failed to connect to/192.168.33.1 (port 80) from / 100.121.61.131 (port 50576) after 1500ms.
    I already tried several time with factory reset. AP mode comes, but still the same issue. I also tried several places (including a place which works for another one). So it may not be WiFi signal.
    I'm a little bit lost, and with nothing else to test. Is there any alternative procedure to install device on my network?
    Thank you for your help.
  • shelly wifi, I get an error:
    If Shelly is in AP-mode, it will have the IP-address 192.168.33.1 by default. Once you join its Wifi network, your smartphone should show 192.168.33.2 .
    If not, is DHCP in your phone not activated?
    Mit der Elektrik ist das doch ganz einfach. Alles, was man sich merken muss: Rot ist Schwarz und Plus ist Minus, dann klappt‘s immer:!: Und beim Programmieren hat man auch nur Nullen und Einsen, also wie kompliziert kann das schon sein:?:
  • Hello ASi-Master,
    I did the test: When connecting manually to the Shelly AP wifi, my phone gets 192.168.33.2 address. But I start the inclusion procedure with phone connected to my home network (DHCP activated). During procedure my phone connects to AP wifi and also gets 192.168.33.2 address, and I finally gets the same error message.
    Sometimes Shelly App doesn't detect shelly device to include during incusion procedure even though I can see the AP wifi by scanning it...
    I don't know if there's a link, but regularly, it takes a few seconds to see the device "online" in the App (Shelly cloud not activated yet on device): I need to go to the previous menu, and come back to see it. Same for parameters menu which doesn't show up every time. Link?
    • Hilfreichste Antwort
    In my experience the Shelly app does not always work.
    I recommend you connect manually to the Shelly AP with your Android phone and use a regular browser to open http://192.168.33.1 .
    Configure your Wifi access point and password over the homepage and the Shelly should afterwards be available in the app (you might need to refresh the app).
  • Hello torusJKL,
    Your procedure seems to work on the first device I tried. I didn't know that each device have a web interface. Shelly should improve their App, or at least explain this second way to connect the device to one's home WiFi...
