Shelly Duo RGBW is not supported by last version OpenHAB
  • Shelly DUO RGBW with OpenHAB 2.5 but also 3.0 is not supported.
    It shows always unknown / configuration error.
    Even GitHub documentation shows it should be supported.
    I have tried
     20210122-154226/v1.10.0-rc1@00eeaa9b
    and
    20210107-122133/1.9_GU10_RGBW@07531e29
    Any idea? Thank you.
    hm. maybe that should be moved to OH section?
  • Just for my understanding, the Shelly Plugin for OH is done by Shelly or is it done by someone else?
    Is this the right forum to find a solution why the Shelly DUO RGBW does not work with OH?
    Thank you so much.
    Hi and welcome to the forum. :)
    It looks, that no user here knows about.
    So you should try in OH-Forum. ;)
  • Solved. After research in the code, it was clear Shelly DUO RGBW is supported.
    Problem is that openHAB 3.0.1 does not include the latest Shelly binding.
    After update to openHAB 3.1.0 M2 (milestone 2, pre-release) it works.
    Connect via Terminal to openHAB: "sudo openhabian-config" you can update it under menu "40"
    maybe that helps someone who has same issue
