Shelly 1L v UK light switch no neutral - can you tell me if I have this right
  • Other than an earth, my light switch has two wires. They go into the COM and the L1 of the switch.
    The wiring diagram for the 1L with no neutral shows wires through the SW1, SW2, Sx, L and O.
    I've got two wires and the diagram has five.
    Is the answer this:
    • The wire which currently goes into COM (main live) now goes into L (line input) on the Shelly.
    • The wire which currently goes into L1 (switched live) now goes into the O (output) on the Shelly.
    • A new wire goes from SW1 on the Shelly to the COM on the switch
    • A new wire goes from Sx to the L1 on the switch.
    Am I close?? Or should the last two be the other way around?
    Thanks
  • Hi, almost close...
    • Shelly 1L
      • L
        • Live
      • O
        • 1 wire to the bulb
        • 1 wire to common of your switch
      • SW1
        • Returns L1 from your switch
      • SW2
        • Nothing if you don’t have a second switch
    Mit der Elektrik ist das doch ganz einfach. Alles, was man sich merken muss: Rot ist Schwarz und Plus ist Minus, dann klappt‘s immer:!: Und beim Programmieren hat man auch nur Nullen und Einsen, also wie kompliziert kann das schon sein:?:
    Einmal editiert, zuletzt von Admin (17. Mai 2024 um 10:28)
  • Hi I have my first Shelly 1L and although the relay is working through the app, my physical toggle switch isn't.
    Did this work out for you please?
    • Shelly 1L
      • L
        • Live
      • O
      • SW1
      • SW2
