Somfy RTS Garage Roller - Which connections?
  • Hello! I'm trying to connect my Shelly 2.5 to my Rollixo RTS garage door.
    I'd like to use one relay to control the opening and closing of the garage door - I have Key Lock terminals on the control panel that allow me to cycle between open - stop - close - stop - open... with each press of a button.
    I'd like to use the other relay to tell me whether I have left the garage door open or not. I'm not sure whether the control panel stores a signal of what position the door is in though.
    The manual for the Rollixo RTS which goes into details of all of the terminals: http://www.rollixo.co.uk/wp-content/upl…L%20ES%20EL.pdf
    A diagram of the terminals in the manual can be found on page 8.
    I've tried reading through the manual to make sense of the connections, however I am struggling to find the correct information of how to connect the Shelly to provide the above use cases.
    I'd appreciate any help on this!
    Thank you.
  • Hello, the shelly 2.5 is no good selection here, because you need a potential free contact to operate the garage door. You should use a shelly 1. For save operation you should use the 24V from the device for supply. Not 230VAC! The next thing is, the door controller gives no Information, whether the door is open or closed. For this, you need an additional Switch. You can find several solutions in the Internet.
    When I'm looking at this picture, you gave to use a shelly 1 for control and when you want checking if you gate is open you need the addon (temperature addon) and something to get the information (Reed contact, a push button or something similar)
