  • I'm using a SHELLY 1 with SHELLY H&T as thermostat. The thermostat in the App uses only integer number to set the temperature (18-19-20...) and regulation is not good enough. Then I've created two scenes, one to turn on (from 9:00 to 21:00 when T is < 19.0°C) and one and turn off the switch (from 21:01 to 9:00 depeding on temperature or the hour) of the SHELLY 1:
    After scenes have been saved sometime names change without a reason (all the same)
    Scenes (this problem has started few days ago) do not activate but need to be open and saved again. After this they run just for one day.
    Is there something else I should other then create & save the scenarios?
    Thanks
    Sandro
  • Both problems described above (name change,need to re-save to activate again) happen to me as well on iOS with door/window v2
  • Andis user here. My scenes won't show up in the app. UNLESS, I create a new scene with the same name of a current scene... Then, they'll show up until the app closes and is restarted. I have about 7 scenes - five of which are the same one I've created over and over just to be able to view and change the settings on the other scenes!
  • I have same problem with my scene names.
    Somtimes, when I change something in scene condition other (not all) scenes are renamed to the newly edited one.
    And there is no way to rename scene to old name. As a result I ended with four scenes with same names.
    So:
    1. Please fix with renaming other scenes
    2. Allow to update scene name from panel
    I have been using panel from web browser instead of Android app.
