Dual Edge button mode
  • I have a physical toggle switch wired into each of the shelly's switch ports. The physical wiring is working fine - the Shelly is detecting state changes on both switch ports correctly.
    Shelly's button mode is set to edge - I'd like a state change on either switch to toggle the output.
    When switch 1 is toggled, it toggles the output - perfect.
    When switch 2 is toggled, nothing happens.
    Is there a setting that'll work in this scenario?
    Is one planned?
    In the meantime, i'll use a homeassistant automation to handle state changes on switch2. Not as fast or reliable, but it'll work for now.
    Thanks.
