Shelly 1L sometimes flickers very quicklywith the relay clicking
  • Hello,
    sometimes happens that the relay starts to switch on / switch off quickly fifteen times without any external action and then stays on.
    Often probably due to the rapid switching, shelly is reset and lost that configuration. If I select detach buttons 1 and 2 in the configuration there is no more problem. I suspect an unstable input level on buttons one and two which could make it look like physical button pressed. The shelly button configuration is in edge mode
  • I’m sorry, can you explain better how did you fix it?
    I’m having the same problem
  • in the shelly interface i have selected this option for the opposite physical switch:
    Detached Switch - Set Shelly device to be in "Detached" switch mode - switch is separated from the relays.
  • Well, with that option you can’t use the physical switch. Am I right?
    Unfortunately that’s still not ideal to me ☹️
